multicast question
NAVIN PARWAL
Level 2
Level 2
I am using autorp how can i preven any new rp with higher ip address from taking over, rp-announce-filter requires me to specify the rp specifically which should be denied, what if I do not know what the new rp is going to be?
n.nandrekar
Level 4
Level 4
Hi!
You dont know which RP addresses you want to filter. But if you know which Ip addresses you can atleast accept as RP, you could use the following command :
Ferrari(config)#ip pim accept-rp auto-rp ?
<1-99> Access-list reference for group
<1300-1999> Access-list reference for group (expanded range)
WORD IP Named Standard Access list
So the device can only accept the IP addresses matching the ip access list and announced through auto-rp as the possible RP.
Niranjan
