multiple OSPF processes and Cisco 3750
Muhammad Khan
I have a 3750 switch stack (Z) at a remote site connected to two 6500 switches (R and P) at two locations over P2P links. I am running multiple OSPF proceses on R and P. I can see the ospf neighorship being established on all switches (R,P,Z) and I can see switch Z receiving routes from switch R but I do not see any routes being advertised by Z towards R. Z is advertising routes to P fine. (Please see the attachments for design and config)
Could anyone suggest anything? Could this be related to IOS version/licening on 3750s? Following is the licening information fro 3750s
Switch   Ports            Model                           SW Version                  SW Image
*    1        54          WS-C3750E-48PD          12.2(35)SE5             C3750E-UNIVERSAL-M
     2        54          WS-C3750E-48PD          12.2(35)SE5             C3750E-UNIVERSAL-M
License Level : ipservices
License Type : Permanent
ankugarg
Level 3
Level 3
This shouldn't be license related,i guess...If something is not available on a particular license,switch will not even allow you to configure that.
Vaibhava Varma
Level 4
Level 4
Hi Muhammad
So here Switch P is receiving the route 192.168.0.0/16 from Switch Z fine but Switch R is not receiving
the route 192.168.0.0/16 from Switch Z. is that correct. How is the OSPF Database looking on Switch R & P.
Can you please share ouput of below on Switch R & P to look further:
sh ip route ospf
sh ip ospf database advertising router 1.1.1.1
sh ip ospf database router advertising router 1.1.1.1
Varma
Hi Verma,
Output  as requested
R#sh ip route ospf 60
R#sh ip ospf database adv-router 1.1.1.1
            OSPF Router with ID (192.168.174.5) (Process ID 60)
                Router Link States (Area 0)
Link ID    ADV Router      Age         Seq#       Checksum Link count
1.1.1.1     1.1.1.1       455         0x800000BE 0x00762A 6
                Net Link States (Area 0)
172.16.253.62    1.1.1.1        455         0x80000038 0x00F716
            OSPF Router with ID (192.168.174.5) (Process ID 1)
R#sh ip ospf database router adv-router 1.1.1.1
  LS age: 606
  Options: (No TOS-capability, DC)
  LS Type: Router Links
  Link State ID: 1.1.1.1
  Advertising Router: 1.1.1.1
  LS Seq Number: 800000BE
  Checksum: 0x762A
  Length: 96
  Number of Links: 6
    Link connected to: a Stub Network
     (Link ID) Network/subnet number: x.x.x.x
     (Link Data) Network Mask: 255.255.255.0
      Number of TOS metrics: 0
       TOS 0 Metrics: 1
       TOS 0 Metrics: 1
     (Link Data) Network Mask: 255.255.254.0
       TOS 0 Metrics: 1
     (Link ID) Network/subnet number: 192.168.0.0
       TOS 0 Metrics: 1
    Link connected to: a Transit Network
     (Link ID) Designated Router address: 172.16.253.69
     (Link Data) Router Interface address: 172.16.253.70
       TOS 0 Metrics: 300
     (Link ID) Designated Router address: 172.16.253.62
     (Link Data) Router Interface address: 172.16.253.62
       TOS 0 Metrics: 1
P#sh ip route ospf 60
     x.x.0.0/16 is variably subnetted, 14 subnets, 5 masks
O       192.168.0.0/24 [110/301] via 172.16.253.70, 1d07h, Vlan470
         <--- Output suppressed --->
P#sh ip ospf database adv-router 1.1.1.1
            OSPF Router with ID (10.1.1.1) (Process ID 60)
1.1.1.1     1.1.1.1     1386        0x800000BE 0x00762A 6
172.16.253.62    1.1.1.1     1386        0x80000038 0x00F716
            OSPF Router with ID (192.168.1.1) (Process ID 2)
            OSPF Router with ID (172.253.1.40) (Process ID 1)
P#sh ip ospf database router adv-route 1.1.1.1
  LS age: 1460
  Checksum: 0x762A
  Length: 96
  Number of Links: 6
       TOS 0 Metrics: 1
       TOS 0 Metrics: 1
       TOS 0 Metrics: 1
       TOS 0 Metrics: 1
       TOS 0 Metrics: 300
       TOS 0 Metrics: 1
Rgds
Hi Muhammad
I am not able to find out any significant difference in the LSDB between two which would cause the issue.
Still I would like to see your full config of the 3 switches once for OSPF Parameters and the relevant Interface config. Is it possible for you to post the same. Did you try reloading the OSPF on R  once and see if it resolves the issue.
Well if this is not a production network and a test environment can you issue  "debug ip ospf spf" and "debug ip routing" on R during the reload.
Hope someone provides a better insight into this interesting issue to reach a resolution.
Varma
