Need help configuring switch
raghavbhardwaj
Hello All,
I want to configure a Cisco 3650 which will have to be connected directly to another big switch (don't know the model) that is already configured. This 3650 will only be used to further provide the LAN connection to a few Cisco IP phones (about 6), few systems (2-3)  and several WAPs (2-3).
I'm still in learning phase and not aware of the proper configurations. It would be great if someone can help me with it the exact configuration.
Raghav
Philip D'Ath
Check out the "macro apply" commands. This applies Cisco's recommend config to a port.
Samples:
macro apply cisco-switch
macro apply cisco-desktop
macro apply cisco-router
macro apply cisco-phone
Hello
Given this requirement - You would probably need to trunk between the big switch, to allow the voice and data traffic to flow.
Also make ready the access/trunk ports for the Phones and the Access points, and this all depends on what type of phone and access-points your using
Do you have access to the big switch -can you post the make/model and if applicable the running config  as eventually you'll need to configure that also for this 3650 to be able to communicate.
res
Paul
Kind Regards
Paul
