Need Help Identifying IOS License
armartinez
     I need help identifying what IOS license is associated with s72033_rp-PK9S-M.
This is the show ver information:
#show ver
IOS (tm) s72033_rp Software (s72033_rp-PK9S-M), Version 12.2(18)SXD3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 09-Dec-04 22:43 by pwade
Image text-base: 0x4002100C, data-base: 0x42318000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PK9S-M), Version 12.2(18)SXD3, RELEASE SOFTWARE (fc1)
iricwypns3-1302 uptime is 10 weeks, 2 days, 10 hours, 15 minutes
Time since iricwypns3-1302 switched to active is 10 weeks, 2 days, 10 hours, 15 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
System image file is "sup-bootflash:s72033-pk9s-mz.122-18.SXD3.bin"
I am used to seeing the License info here but this appears to be a release that used the old code methode.
I need this info for the software advisor.
Thanks.
5 Replies 5
handoko wiyanto
Level 3
Level 3
hi,
after going to cisco.com/go/fn
and selectin choose by image, i put in the image name: s72033-pk9s-mz.122-18.SXD3.bin
it shows that the feature set is IP W/SSH/3 DES LAN ONLY
regards,
Thanks!
I am trying to do as you described by going to the same website, it redirects me to http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp, I see a "search by image" and had no luck when I put the image name in the blank and searched.
I will continue to try to replicate your search.
Thank you!
thats correct, im refering to the same page between cisco.com/go/fn and http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
just did once again, and it works out for me. have you login to the site?
regards,
Yes, I am logged in.
I was also having issues with the downloader starting so I shut down my browser and restarted it.
I am now able to replicate your search.
Thanks again!
good, nice to know that you solve the issue.
regards,
