05-27-2017 07:32 AM - edited 03-08-2019 10:45 AM
I am very new to the cisco community and I am all lost.
I need help installing the usb serial controller on my windows 7 machine. I would like to set up my 3750 switch in Putty, but when i connect it to the computer, the device manager says it's missing the usb controller.
I downloaded this usb console driver off the cisco website, but it's still not working.
I would appreciate if someone could direct me to the right path.
Thank you in advance
05-27-2017 08:05 AM
Hi Sandra,
Usually the USB-Serial adapters are manufactured by third party companies, I have had similar issues like you mentioned, I suggest search the driver on google using the brand or serial number. Cisco devices don't use drivers, the drivers belong to the adapters.
The brand new adapters include a CD with many drivers have you tried to install them?
Check this link:
https://www.google.com.sv/search?q=usb-serial+controller&rlz=1C1HIJA_enSV704SV704&oq=usb-serial+controller&aqs=chrome.0.0l6.7158j0j8&sourceid=chrome&ie=UTF-8
05-29-2017 06:45 AM
Thank you for your reply.
This 3rd adapter don't have a serial number or info I can look up.(A friend gave it to me...)
I also have a usb console driver that I received with the switch (bought it off ebay). Device manager says it's on com4 but putty doesn't recognize it. I get the black window in Putty.
Thank you again
05-29-2017 06:45 AM
Hi Sandra,
I would like to recommend the adapter I bought a time ago and it works perfectly:
https://www.amazon.com/Plugable-Adapter-Prolific-PL2303HX-Chipset/dp/B00425S1H8/ref=sr_1_1?ie=UTF8&qid=1496065437&sr=8-1&keywords=pl2303-db9
Hope it is useful
06-12-2017 11:12 PM
Thank you. I bought the adaptor that you recommended me and it works like a charm.
thank you again
06-13-2017 05:26 AM
Perfect! good to know that.
Have a great day.
