Netflow on 6509 - missing lots of traffic
roger perkin
Level 2
Level 2
I have setup Netflow on our 6509 and it is reporting some traffic, but it appears today not all!
My Netflow monitoring was showing about 5Mbs usage across our replication link when in fact it was running at 100Mbs killing the line.
Config on the netflow is like this
ip flow-cache timeout active 1
ip flow ingress layer2-switched vlan 903,998
mls netflow interface
mls flow ip interface-full
mls nde sender version 5
** this is the bit I am not sure on **
interface Port-channel100
description Site to Site Connection
no switchport
ip address 10.252.255.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
Firstly this is a Layer 2 interface and I am not sure about Netflow working on it?
The Vlan that the server generating the traffic is in is defined in the FWSM
So I have done this hoping it will catch all the traffic coming out.
interface Vlan999
description FWSM Outside
ip address 10.251.251.241 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
end
So the issue - a server generating a lot of replication traffic is not outputting this in Netflow
I am not sure how to test this as I have been told to get a 6509 configured for Netflow is quite tricky.
Any help advice would be appreciated
Roger
roger perkin
Level 2
Level 2
Having researched this a bit more it appears the only way to get Netflow stats out of devices underneath the FWSM is to enable it on the communication channel between FWSM and 6500
I assume this to be on my setup vlan 999, other posts I have read is to enable Layer 2 and Layer 3 netflow on this interface
So the config on this interface now looks like this
interface Vlan999
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress - (Layer 3 Netflow )
end
ip flow ingress layer2-switched vlan 903,998-999
Roger
It looks like you have most of it configured correctly, so you may have something with the FWSM that's affecting it. Try this:
mls aging long 64
mls aging normal 64
mls cef error action freeze
ip flow ingress layer2-switched vlan 1,95,126,140
ip flow-export version 5
ip flow-export destination
ip flow-top-talkers
Then under each VLAN you'd need to enable ip flow ingress/egress....
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080721701.shtml
As far as the FWSM, I'm not sure...I've only worked with ASAs, and I'm not sure they're the same.
HTH,
John
HTH, John *** Please rate all useful posts ***
