Network types
jonk34567
Level 6
Level 6
Ospf has network types .( frame relay, broadcast network ) does Rip and Eigrp also has network types ?
Julio E. Moisa
Good question, in OSPF you can configure the network type on the interfaces explicity, also depending of the network requirements.
http://packetlife.net/blog/2008/jun/19/ospf-network-types/
Now in RIP or EIGRP there is no way to configure the interfaces like OSPF but they can work over Broadcast, NBMA (Non Broadcast Multi Access) types and Point-to-Points for example using Serial interfaces. Now take in consideration the theory of Split Horizon when you are using EIGRP and RIP on NBMA networks.
Split-Horizon is enabled by default, if a prefix or packet is known through a physical interface this physical interface cannot advertise the same prefix learned, in few words the packet will dropped.
http://packetlife.net/blog/2008/nov/03/disabling-split-horizon/
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
so if i am working on frame relay network in  rip  i have to disable split-horizon or poison reverse.
If you have a NBMA network and you are using vector distance routing protocols like RIP or EIGRP you need to disable the split horizon in order to avoid drop packets.
