Nexus 5000 DSCP marking for default-class
schitrakar
I was trying to mark DSCP on default-class to 0 (default) on inbound policy type qos,
policy-map type qos non-VoIP
  class type qos class-default
     set dscp default
But, it gave me a error, saying
ERROR: class-default cannot be modified
I am running Nexus 5548P with 5.0(2)N2(1).
Sharad
sfaizul
Please check this .
Configuring Weighted Fair Queuing
This is the configuration guide for the feature. In here you'll find all the information needed.
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/config_wfq_ps6350_TSD_Products_Configuration_Guide_Chapter.html
gsckolnick
You can do this, but the syntax is a bit different:
class class-default
     set dscp default
~Gary
I am under the impression that you can do DSCP marking only on the 5548 of the 5k Series.
For the rest you can only map down dscp->cos and do your marking on cos (or vice versa).
I will try to find the reference documentation.
rGrds
George
Update:
You can see from the following document:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/qos/503_n1_1/b_cisco_nexus_5000_qos_config_gd_503.html
There is reference for marking DSCP only for 5548.
Ofcourse DSCP Classification can be done (with 'match') on all 5k
Hope this helps
rGrds
George
Message was edited by: George Karavitis
