no syslog message when Cat4500 module removed
croue
I have a Cisco Catalyst 4507R with two Sup-Engine V-10GE.
When I remove from the chassis the active SUP-Engine, the switchover works fine, but there is no syslog message on the LMS syslog.
When I re-insert the module in the chassis, syslog messages appeared well on LMS syslog (module inserted).
The IOS is: 12.2(31)SGA1
the config is:
logging 172.30.7.240
snmp-server community fread RO
snmp-server community fwrite RW
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server host 172.30.7.240 f1matread
ankbhasi
Hi Friend,
Can you configure these 2 commands and update the status
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
Ankur
The problem is not resolved.
The logs that appear on the Cat4507R console are:
May 18 06:58:22.902: %C4K_IOSMODPORTMAN-6-MODULEOFFLINE: Module 2 is offline
May 18 06:58:23.906: %C4K_IOSMODPORTMAN-6-MODULEREMOVED: Module 2 is removed
But thez don't appear on the LMS Syslog.
