No system configuration dialogue .
Aleko
I'm 68% done with the first guided activity when I'm supposed to configure the backup router in Seward Alaska. It gives me in guided instructions but the laptop terminal doesn't do what the tutorial says it should. The tutorial shows a line of system config dialogue asking if I want to access config interface to which I'm supposed to type no and then be able to get into the router. But my terminal won't show that. It just says trancieving. Plz help
8 Replies 8
Mark Elsen
 - Tell us at least why type/model of Cisco device you are trying to configure and or post a screenshot  of the 'place' where you are currently stuck at.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
It hasn't been saying trancieving........ But still no system configuration
dialogue.
Aleko,
What Cisco Netacad course are you taking and which Packet Tracer activity are you having trouble on? What part of the tutorial are you on?; Example: Part 3, step 4c.
To expedite helping you, please provide the tutorial and Packet Tracer files.
Doesn't show what steps
Am I required to be connected to internet to use packet tracer?
Yes.
**bleep** that might be the problem
##- Please type your reply above this line -
