Not able to configure SSH
md farook
Dear Friends,
    There is router in my network in which SSH was working fine. due to some reason we erased all configuration. after that im not get console of router via SSH eventhogh i have configured Transparent input SSH.there is one more router in which only Transparent input SSH has configured and it is working fine. Kindly suggest.
andrew.prince
Level 10
Level 10
If you have manually erased the router config, you need to regenerate the SSH keys for SSH to work:-
You must configure the device name & a domain name - once configured generate the SSH keys
crypto key gen rsa general-keys mod <>]
once generated you will be able to SSH.
HTH>
Andrew.
droeun141
Need to regenerate your keys:
cry key gen rsa
Mod size: (we usually use 1024)
Router#sh ip ssh
SSH Enabled - version 2.0
Authentication timeout: 60 secs; Authentication retries: 3
Thank you all for support
