12-19-2011 05:46 AM - edited 03-07-2019 03:57 AM
Hi I am looking for optical transceivers that are compatible with the Cisco 5509 switch. Preferably 1G.
Please help.
Tom
Solved! Go to Solution.
12-19-2011 02:15 PM
Please help.
Tom
Gigabit fibre modules on the 5509 series switch use GBIC interfaces.
Cisco part numbers are as follows
The SX is good for up to 550 metres, depending on cable specifications, the LX/LH is good for up to 10 kilometres, depending on cable type (550 metres on everything except single mode fibre), and the ZX is good for up to 100 kilometres (single mode fibre only).
If you google for "cisco GBIC retail" you can find places to guy them from.
Cheers.
12-19-2011 07:49 AM
Hi Tom,
Check the below link...
hth
MS
12-19-2011 10:15 PM
Darren,
Thanks for the info, i'll do that.
Cheers
12-19-2011 02:15 PM
Please help.
Tom
Cheers.
