OSPF Forward Metric
ccnp_seeker
I have set OSPF to choose between two paths. Here is the output from what I have:
lab_R1#sh ip route 10.254.7.1
Routing entry for 10.254.7.0/30
Known via "ospf 10", distance 110, metric 28, type intra area
Last update from 172.16.1.193 on Vlan1, 00:26:01 ago
Routing Descriptor Blocks:
* 172.16.1.193, from 172.16.1.17, 00:26:01 ago, via Vlan1
Route metric is 28, traffic share count is 1
lab_R1#sh ip route 10.254.6.73
Routing entry for 10.254.6.72/30
Known via "ospf 10", distance 110, metric 23, type intra area
Last update from 172.16.1.193 on Vlan1, 00:26:05 ago
* 172.16.1.193, from 172.16.1.19, 00:26:05 ago, via Vlan1
Route metric is 23, traffic share count is 1
as you can see the route to 10.254.7.1 has a higher cost, so it should no be the preferred link, but in fact this is the preferred link when I make a trace.
I also have notice in the end routers that I am receiving this routes, but the 10.254.7.1 has a lower "Forward Metric", I'm not sure if this is the reason for this behavior.
Also I tried confioguring the ip ospf X command, but it still prefer the 10.254.7.1 path, no matter what cost is on the other.
Any idea on the Forward Metric topic? I have being researching on the web but there is no clear information about it.
regards...
Giuseppe Larosa
Hello Seeker,
the two sh ip route you have posted are about two different disjointed /30 IP subnets:
Then if you have inter Area routes or external routes of type O E2 the forward metric can be the metric to reach the ASBR.
The O E2 type of external routes keep separated the seed metric and doesn't sum it to the internal part of the metric.
However, by running SPF over LSA type 4 (ASBR summary LSA) every router can calculate the forward metric to reach the LSA type 5 owner/originator.
So forward metric should refer to the metric to reach the ASBR/ABR and may differ from the next-hop used.
If the OSPF Router-IDs are advertised in OSPF I think that forward metric is the metric to reach ASBR/ABR router-id ip address if forwarding address=0.0.0.0 (=this node) in LSA type 5.
Or if the forwarding address in the LSA type 5 is different from 0.0.0.0 it is the metric to reach that ip address.
Hope to help
Giuseppe
Nice, so much clear.
thanks...
