packet sniffing a trunk link
carl_townshend
Hi all, If I set up a trunk with all my vlans on one port, if I use ethereal and plug into it, will I see all broadcasts etc for all vlans?
When using ethereal, am i right in saying it still works without an ip ?
ropethic
Level 4
Level 4
You will need to setup a SPAN session with the trunked port as the source port to a destination port where the sniffer will be plugged into.
When monitoring a trunk source port all active vlan traffic is monitored.
You dont need an IP in order capture data.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
jedavis
Level 4
Level 4
Hi Carl,
I believe that is true - you see all the traffic on all the Vlans. However, I think that span may strip off the dot1q headers so you don't know what vlan any particular packet came from. Set up a span/port monitoring session and give it a try. You have nothing to lose.
Ethereal (AKA Wireshark) does not even need the IP protocol bound to the monitor NIC.
