PAT Overload between internal networks
Mark Rigby
Greetings, i have an 871 ISR, the outside interface is configured with two sub interfaces and an internal LAN interfaces, now im trying to get the 172.16.1.0 network to talk to the 10.10.10.0 network which doesnt have a GW of it's own, as such i need to translate the 172.16.1.0 network to the IP address of the F4.75 interface 10.10.10.1
I though this would be simple in theory but its proving annoying.
F4.50 - Internet Facing
ip address 1.1.1.1 255.255.255.0
ip nat outside
F4.75 - Internal LAN
10.10.10.1 255.255.255.0
ip nat ?
The internal Vlan1 interface is attatched to a private network
VLAN1
ip address 172.16.1.0 255.255.255.0
ip nat inside
I can get to the internet fine  using
ip nat inside  source list 100 interface F4.50 overload
access-list  100 permit 172.16.1.0 0.0.0.255 any
However i cant PAT to  the 10.10.10.0 network using the same method, ive tried setting the  interface to OUTSIDE the doing the following but to no avail.
interface F4.75
ip nat outside
ip nat inside source list  101 interface F4.75 overload
access-list  101 permit 172.16.1.0 0.0.0.255 10.10.10.0 0.0.0.255
Any recomendations are welcome
Ganesh Hariharan
ip nat outside
ip nat ?
VLAN1
ip nat inside
Are you telling the sub interface are configured in outside interface but in the above config 10.10.10.X is int intenal segment and traffic 172.16.1.0 is alos coming from internal segment i suppose.
You can create mutliple internal subinterface and make use of pat in the baove config with making gateway as the sub interface ip of the router.
Hope to Help !!
Ganesh.H
Greetings, yes i have configured "ip nat outside" on the sub interfaces, this is the current configuration.
I want to PAT "overload" between the internal LAN 172.16.1.0 255.255.255.0 and a second internal LAN 10.10.10.0 . It is this way because the clients on the 10.10.10.0 network dont know of the other internal network 172.16.1.0 and dont know how to route to it as 10.10.10.1 isnt there default gateway, if i try to communicate with a host on the 10.10.10.0 network without NAT the source IP comes from the 172.16.1.0 network which they dont know how to get too hence PAT.
Unfortunatrley this config doesnt work, do i need to use route maps instead?
interface f4
no ip address
interface f4.50 - Internet Facing
encapsulation dot1q 50
ip nat outside
interface f4.75  - Internal LAN
encapsulation dot1q 75
ip nat outside
interface vlan1
ip address 172.16.1.1 255.255.255.0
ip nat  inside
ip nat inside source list 100 interface f4.50 overload
ip nat inside source list 101 interface  f4.75 overload
access-list 100 permit ip 172.16.1.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 101 permit ip 172.16.1.0 0.0.0.255 any
Is this one for route-maps or isnt it possible to PAT between two RFC 1918 network ranges?
