PBR and VRF on C3750
Rob Gagnon
I've been trying to get a local policy based route with VRF working on a 3750 running IOS 12.2(44)SE5.
Here's the relevant config:
ip vrf Test
rd 65500:10
interface Loopback1
ip vrf forwarding Test
ip address 172.31.16.1 255.255.255.255
interface GigabitEthernet1/0/11
description Next-Hop
no switchport
ip address 172.17.16.29 255.255.255.252
router eigrp 1
address-family ipv4 vrf Test
redistribute static route-map eigrp-redist
ip access-list standard STATIC-SLA
permit 172.21.4.236
ip access-list extended LOCALPBRACL
permit icmp host 172.31.16.1 host 172.21.4.236
route-map LOCALPBR permit 10
match ip address LOCALPBRACL
set ip next-hop in-vrf Test
set ip next-hop 172.17.16.30
route-map eigrp-redist permit 20
match ip address STATIC-SLA
ip local policy route-map LOCALPBR
ip sla 20
icmp-echo 172.21.4.236 source-ip 172.31.16.1
vrf Test
ip sla schedule 20 life forever start-time now
track 20 ip route 172.21.4.236 255.255.255.255 reachability
delay down 15
ip route vrf Test 172.21.4.236 255.255.255.255 172.17.16.30 track 20
3750#sho route-map
route-map LOCALPBR, permit, sequence 10
Match clauses:
ip address (access-lists): LOCALPBRACL
Set clauses:
ip next-hop vrf Test 172.17.16.30
Policy routing matches: 358 packets, 24106 bytes
3750#debug ip policy
Mar 16 12:45:04: IP: s=172.31.16.1 (local), d=172.21.4.236, len 64, policy match
Mar 16 12:45:04: IP: route map LOCALPBR, item 10, permit
Mar 16 12:45:04: IP: s=172.31.16.1 (local), d=172.21.4.236, len 64, policy rejected -- normal forwarding
This appears to be a very similar issue as another older post
https://supportforums.cisco.com/discussion/11264676/multi-vrf-and-policy-based-routing-catalyst-3750
I have this working properly, (though slightly different config) on a 4500 running IOS-XE 03.06.05.E.
Any help would be greatly appreciated.
Philip D'Ath
First make sure you are using an sdm template that supports PBR.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_58_se/configuration/guide/3750scg/swsdm.html
Next, as a matter of interest, if you match "ip" insyead of "icmp" does that work?  It may just be a limitation on that platform and software version with the match criteria.
Lastly, 12.2 is pretty old.  Any reason why you can't run something a bit more modern?
Hi Philip,
First off, thanks very much for the input!
I'm using the desktop routing SDM template:
3750#sho sdm prefer
The current template is "desktop routing" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 3K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 11K
number of directly-connected IPv4 hosts: 3K
number of indirect IPv4 routes: 8K
number of IPv4 policy based routing aces: 0.5K
number of IPv4/MAC qos aces: 0.5K
number of IPv4/MAC security aces: 1K
I also tried changing the ACL to permit IP.
Extended IP access list LOCALPBRACL
10 permit ip host 172.31.16.1 host 172.21.4.236 (1 match)
The result appears to be the same :
Mar 22 08:36:13: IP: s=172.31.16.1 (local), d=172.21.4.236, len 64, policy match
Mar 22 08:36:13: IP: route map LOCALPBR, item 10, permit
Mar 22 08:36:13: IP: s=172.31.16.1 (local), d=172.21.4.236, len 64, policy rejected -- normal forwarding
Entry number: 20
Owner:
Tag:
Type of operation to perform: echo
Target address: 172.21.4.236
Source address: 172.31.16.1
Request size (ARR data portion): 28
Operation timeout (milliseconds): 5000
Type Of Service parameters: 0x0
Verify data: No
Vrf Name: Test
Schedule:
Operation frequency (seconds): 60
Next Scheduled Start Time: Start Time already passed
Group Scheduled : FALSE
Randomly Scheduled : FALSE
Life (seconds): Forever
Entry Ageout (seconds): never
Recurring (Starting Everyday): FALSE
Status of entry (SNMP RowStatus): Active
Threshold (milliseconds): 5000
Distribution Statistics:
Number of statistic hours kept: 2
Number of statistic distribution buckets kept: 1
Statistic distribution interval (milliseconds): 20
History Statistics:
Number of history Lives kept: 0
Number of history Buckets kept: 15
History Filter Type: None
Enhanced History:
Round Trip Time (RTT) for Index 20
Type of operation: icmp-echo
Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: 08:41:13.944 CDT Wed Mar 22 2017
Latest operation return code: Timeout
Number of successes: 0
Number of failures: 52
Operation time to live: Forever
This is the latest Cisco recommended software for the 3750:
https://software.cisco.com/download/release.html?mdfid=278169764&flowid=&softwareid=280805680&release=12.2.55-SE11&relind=AVAILABLE&rellifecycle=ED&reltype=latest
If you know of another version that's newer and will work on a 3750, I can give it a shot. I'm thinking this may either be a bug or a limitation of IOS.
Just realized that I wrote the wrong IOS version. It's running 12.2(55)SE11.
Time to buy a new Cisco 3850 or perhaps an ASR920 or maybe even an ME3800X ...
