PBR doesn't work
dinocecchini
i have a problem with a PBR statement.
in juniper this statement work fine, but now i change the juniper with a Cisco 4500X.
I try to disable the cef on the interface vlan but nothing.. what can be?
the juniper per config and the cisco per config are attached.
30 Replies 30
Dino
Thanks for the additional information. Based on this it looks like the configuration of PBR is right. If it is not working we need more information about the environment and probably more of the config to help us find the problem. Perhaps the output of the commands show route-map, show access-list, and show ip interface brief might be helpful.
Rick
Rick
Hi Richard,
Thanks for the support.
This is the output:
  • sh access-list:
Extended IP access list 118
    10 permit ip host 10.51.243.221 any
  • sh route-map
route-map PBR118, permit, sequence 10
  Match clauses:
    ip address (access-lists): 118
  Set clauses:
    ip next-hop 192.168.0.1
  Policy routing matches: 0 packets, 0 bytes
  • sh ip int br | ex una
Interface              IP-Address      OK? Method Status                Protocol
Vlan10                 192.168.0.10    YES NVRAM  up                    up
Vlan201                10.53.6.1       YES NVRAM  up                    up
Vlan301                10.52.6.1       YES NVRAM  up                    up
Vlan401                10.51.6.1       YES NVRAM  up                    up
Vlan501                192.168.150.1   YES NVRAM  up                    up
Thanks again
Were you able to check your sdm template as I suggested in an earlier post? It seems that Aref was able to check his and had to make a change for pbr to work. This may be what your cause is....
HTH, John *** Please rate all useful posts ***
Hi John,
sorry but i forgot to tell you that i can't verify because the command "show sdm prefer"  is not present. I try to find some alternatives but nothing of similar.
Thanks again
This is the ios version that runs on my Switch:
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Aref
My apologies. I didn't realize Aref is working with a 3550. I don't believe the 4500 series requires that.
I'm going to ask the obvious. Is routing enabled on the switch?
Yes, the routing is enabled.
it's possible a cef problem?
thanks
Honestly I need to read more about the difference between the command I applied and the one you mentioned in your erlier post, here what I see on my switch:
Switch#sh sdm prefer
 The current template is the default extended-match template.
Aref
I lab it up, at the beginning it did not work then I enabled some debugs and I noticed this error message "PBR L3TCAM−3−SIZE_CONFLICT: PBR requires enabling extended routing", looking for a reason and a solution, I found that I needed to apply the command "sdm prefer extended-match" in order to make the route map works on my switch (3550), in fact before applying that command, the ip policy route-map was not neither taken under the vlan 501 interface, but once I applied it the ip policy route-map command has been taken. You need to reload you switch after applying "sdm prefer extended-match".
Now in regard to the fact of receiving packets from a differnt network on vlan 501, there is no problem at all, at least from what I have seen in my lab, I simulated a design similar to yours, and the packets comming from the host 10.51.243.1 on interface vlan 501 (192.168.150.0/24) have been matched on the access list 118 and the route map works properly.
I hope this would be helpful.
Aref
Hi Aref,
Thanks for the support and for the patience.
I appreciate that you try in lab the my case! Now i'm out of office, tomorrow i try to configure as you said me and hope that work.
Thanks again,
Dino
You are very welcome Dino, try that when you are able to and let us know if it solves the issue.
Aref
Hi Aref,
i connect by VPN and i check that the command"sdm prefer extended-match" is not implemented in my switch.
Hello
If it localy originating from you network
ip sla 1
type echo protocol ip icmp echo 192.168.0.1
 rtr schedule 1 life forever start-time now
track 10 rtr 1 reachability
route-map PBR118 permit 10
match ip address 118
set ip next-hop  192.168.0.1
set ip next-hop verify-availability 192.168.0.1 1track 10
route-map PBR118 permit 99
int vlan 501
ip  policy route-map  PBR118
int x/x (physical interface)
res
Paul
Kind Regards
Paul
Hi Paul,
sorry for the late reply.
you say that it should be implemented in physical interface from where I get the traffic?
Dino
Dino
Assuming that the physical interface where you receive the traffic is a layer 2 interface you do not need to configure ip policy on it (and I believe that the command would be rejected if you try since ip policy is a layer 3 function which would not operate on a layer 2 interface).
Paul
Using verify-availability is an interesting idea and would help prevent the situation where PBR is attempting to forward but the specified next hop is really not reachable. But I do not think that this fits the current problem which is that PBR is not forwarding the traffic. And I do not understand the purpose of route-map PBR118 permit 99. If the route map were used to help control a dynamic routing protocol (to alter metrics, or to prepend, or something like that) then the entry with no match and no set will allow remaining traffic to be processed without change. But what purpose would it serve in PBR?
Rick
Rick
