PBX connected to our IAD is not able to make/receive calls - error log on IAD
bfeole001
I'm getting a series of error messages that I don't understand as I'm new to troubleshooting on an IAD. I'm not sure if they would prevent a pbx from making/receiving calls (that's the  main issue here). Any help would be appreciated. I did find http://www.cisco.com/c/en/us/td/docs/ios/system/messages/guide/sm_cn04.html and that indicates a recommended action but I'm not sure what any of it really means. For example on the the 'resetting connections to 0' alert, it says 'Recommended Action - Check to see if dial peers were removed while active calls were still associated to them, and then those dial peers were reinserted while the calls were still connected. ' I don't know how to do that. For all I know it's a problem with the pbx but I want to make sure the IAD is functioning ok.
Oct 26 10:47:28: %SCHED-3-THRASHING: Process thrashing on watched queue
'_ManagedAppProcess_Default'. -Process= "AFW_application_process", ipl=
4, pid= 25 -Traceback= 0x604AFF2C 0x605C0288 0x605C036C 0x618836E8
0x605AFFCC 0x605AFFB0
Oct 26 10:47:39: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for
CCAPI Event po. No memory available -Process= "Chunk Manager", ipl= 4,
pid= 1 -Traceback= 0x604AFF2C 0x6060F130 0x605AFFCC 0x605AFFB0
Oct 26 10:47:39: %DIALPEER_DB-3-DIALPEER_ACCOUNTING: Connections for
dial-peer 101 is negative. Resetting connections to 0.
Oct 26 10:48:05: %DIALPEER_DB-3-DIALPEER_ACCOUNTING: Connections for
Me
0 Replies 0
