Ping ISP gateway OK from Outside interface. Inside not ok.
Cyantist
Hello guys,
I'm quite new to Cisco & networking. I have a brand new Cisco ASA 5506-X that I want to configure to go to the internet. So i used ASDM to configure the router.
The local network is 192.168.107.0 /24 so Inside interface is 192.168.107.1
Outside interface is 37.71.120.114 /30 (Public IP Address provided by ISP) and the gateway is 37.71.120.113.
So the actual cfg is: Modem >>>> (Outside interface) Cisco ASA (Inside interface) >>>>> LAN
I can ping the gateway provided by the ISP with ASDM from Outside Interface but I can't ping it from the Inside Interface. I can't ping any other IP from the outside interface (tried to ping many Public IP, always timeout).
So First I tired to setup PAT with static route but this dosn't seems to change anything. I don't get it.
Here is the CFG:
https://pastebin.com/TT5w775F
If you see anything wrong tell me, as i said i'm new to this so i may have done something stupid.
Cheers.
10 Replies 10
Julio E. Moisa
Try to add these lines on your config
access-list INSIDE-ACL line 1 extended icmp any any echo
access-list INSIDE-ACL line 1 extended icmp any any echo-reply
access-list INSIDE-ACL line 1 extended permit ip any any
access-group INSIDE-ACL in interface inside
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
in addition to Julio's post I think you also need an inbound access list on the outside interface:
access-list OUT_IN extended permit icmp any any echo
access-group OUT_IN in interface outside
Hey guys,
Thx you. So i entered those commands:
access-list INSIDE-ACL line 1 extended permit icmp any any echo
access-list INSIDE-ACL line 1 extended permit icmp any any echo-reply
I still can't ping my gateway from inside interface... I don't understand why i should use ACL to get the ICMP reply because if the client (in LAN) initiate the request it should get the answer without using ACls?
Here is my config now: https://pastebin.com/jn9sA57u
Try including:
access-list OUT_IN extended permit icmp any any echo-reply
I did add this line, reboot the router, can't ping... :'( Maybe an issue with the ISP? Because from outside interface i can ping the gateway but not any public IP...
Usually the firewall protect the local interface to avoid ping o traceroute. How are you trying? on older devices you could not specify the source how we do on routers.
I use the ASDM to ping IP so i can choose from wich interface or IP address i want to ping with. I also tried to connect a computer to the local network and ping gateway and i don't get any response from isp gateway or other public address. May i should try an other way?
If you are trying from a PC you should get a response, try to ping 8.8.8.8, also verify the IP settings on the PC.
Im going to double check your config.
Try with
no nat (any,outside) dynamic interface
no nat (inside,outside) after-auto source dynamic any interface
object network obj_any
no network 0.0.0.0 0.0.0.0
network-object 192.168.107.0  255.255.255.0
nat (inside,outside) dynamic interface
So everything network you include on this object-group will be natted.
try and add the below to your configuration:
icmp permit any outside
icmp permit any unreachable outside
icmp permit any echo outside
icmp permit any echo-reply outside
icmp permit any time-exceeded outside
icmp permit 37.71.120.112 255.255.255.252 outside
icmp permit 192.168.107.0 255.255.255.0 outside
icmp permit any inside
icmp permit 192.168.107.0 255.255.255.0 inside
