03-05-2013 08:10 PM - edited 03-07-2019 12:04 PM
Hai,
I ahave one cisco Nexus 7000 with version 6.1(2).
I created 3 VDC
ADMIN
CORE
security
I have configured 1 - 45 ports for Core and 46 - 48 ports for Security.
Now I am not using the VDC Security and I tried to move the assigned ports 46 - 48 from Security to ADMIN.
Switch accepted the command .But the ports are not visible on ADMIN VDC.Now it is not showing on Security VDC also.
I need this ports in ADMIN VDC
Is there any way to resolve this ?
Thanks in advance
03-05-2013 08:46 PM
Hi Sree,
I did this testing and it is working fine for me. Please see below:
Nexus7K(config-vdc)# show vdc membership
vdc_id: 1 vdc_name: Nexus7010 interfaces:
Ethernet2/10 Ethernet2/12 Ethernet2/14
Ethernet2/31 Ethernet2/32
Nexus7K(config-vdc)# no allocate interface e2/32 <<<< Removing the e2/32 interface from the vdc.
2- Adding this interface to other VDC.
Nexus7K(config-vdc)# vdc Inayath
Nexus7K(config-vdc)# allocate interface e2/32 <<< Added the interface
Nexus7K# show vdc mem
vdc_id: 4 vdc_name: Inayath interfaces:
Ethernet2/2 Ethernet2/4 Ethernet2/6
Ethernet2/8 Ethernet2/26 Ethernet2/28
Ethernet2/30 Ethernet2/32 <<<<<<<<<<<<<<<<<<<<<, Interface is showing in this now.
Same been followed to put back the interface and its working fine.
Please check the same again and let me know.
Make sure you login to the admin vdc and allocate the interface46-48 on that vdc.
Inayath
*plz rate the usefull posts.
03-06-2013 04:36 AM
Dear Inayath,
Thanks for the reply.
I have done this and successfully unallocated.
But I am unable to add this into ADMIN VDC.Command is accepted. But this ports are not visible on ADMIN VDC
Is there any way to fix this
Thanks in advance
Sreelal
03-06-2013 05:36 AM
Hi Sreelal,
Can you please share the output of show vdc and show vdc membership?
Inayath
03-10-2013 01:17 AM
hai,
Please find the output.Here I can see that the ports are in vdc_id: 0.
How we can move this ports to vdc_id: 1 vdc_name: NX02-
NX02-# show vdc
vdc_id vdc_name state mac type lc
1 NX02- active 40:55:39:0d:f4:41 Admin None
2 CORE-SW active 40:55:39:0d:f4:42 Ethernet m1 f1 m1xl m2xl
NX02-# show vdc membership
vdc_id: 0 vdc_name: Unallocated interfaces:
Ethernet3/20 Ethernet3/21 Ethernet3/22
Ethernet3/23 Ethernet3/24
Ethernet4/45 Ethernet4/46 Ethernet4/47
Ethernet4/48
vdc_id: 1 vdc_name: NX02- interfaces:
vdc_id: 2 vdc_name: CORE-SW interfaces:
Ethernet3/1 Ethernet3/2 Ethernet3/3
Ethernet3/4 Ethernet3/5 Ethernet3/6
Ethernet3/7 Ethernet3/8 Ethernet3/9
Ethernet3/10 Ethernet3/11 Ethernet3/12
Ethernet3/13 Ethernet3/14 Ethernet3/15
Ethernet3/16 Ethernet3/17 Ethernet3/18
Ethernet3/19
NX02-(config)# vdc NX02-
NX02-(config-vdc)# allocate interface ethernet 4/48
Moving ports will cause all config associated to them in source vdc to be removed. Are you sure you want to move the ports (y/n)? [yes]
But the port is still not in admin VDC
03-10-2013 10:00 AM
Admin VDC is the default VDC and you can't allocate ports to it. Admin VDC is just for management and for when you need to turn on certain features.
09-03-2018 02:12 AM
how can we see unallocated ports on the nexus 7Ks?
03-10-2013 06:16 PM
Hi Sree,
Yes as Reza said you allocate this interface to any other VDC other than Admin VDC and you should be able to do that.
Please find below the Guidelines and Limitations for Creating Admin VDCs:
No interfaces from any line card module can be allocated to an admin VDC. Only mgmt0 can be allocated to an admin VDC which means that for an admin VDC, only out-of-band management is possible through the mgmt0 interface and console port."
Ref:
Inayath
*Plz rate the usefull posts.
