Port-channel switching module cisco ASR4431
opineiro1
Hi.
I have a switching module NIM-ES2-8 in a ASR4431 but I can´t configure channel-group command in the interface.
The cisco ASR 4431 only can configure port-channel in the Front Panel 4 ports Gigabitethernet Module?
Reza Sharifi
Correct. Only the onboard interfaces support Portchannel. It should support both LACP and mode "on"
Reza Sharifi
is there any kind of external module which supports portchannel configuration for a 4451?
Maybe the SM-X Layer 2/3 EtherSwitch Modules? As far as i can see there is a minimum of 16-port module. Any chance to get an 8-port module for the first row of 4451 back panel?
Thanks and regards
Leo Laohoo
Be careful of CSCvw74609.
