Port Forwarding Cisco 1841
Berglund09
I need to forward  the following ports to an internal static IP 192.168.XX.XXX for my 3cx server
5060 TCP
5090TCP
9000-9049 UDP
Can someone help me with this?
Pranay Prasoon
Level 3
Level 3
ip nat inside source static tcp <server ip> 5060 <outside ip> 5060
ip nat inside source static tcp <server ip> 5090 <outside ip> 5090
ip nat inside source static udp <server ip> 9000 <outside ip> 9000 ///you will most probably need to create the statements for all udp ports
