Port-forwarding lost when DSL connection drops - Cisco 887W
jamieburgess
Everytime the ISP resets the DSL connection for maitenance, the portforwarding stops working, and needs to be entered again. Is there anything wrong with the config below?
Version is C880DATA-UNIVERSALK9-M), Version 15.0(1)M7, RELEASE SOFTWARE (fc2)
version 15.0
no service pad
service password-encryption
no service dhcp
hostname XXX-Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa session-id common
memory-size iomem 10
clock timezone PCTime 10
clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-XXXXXXXXXXX
X
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certifi
cate-XXXXX
XXXXXXXX
revocation-check none
rsakeypair TP-self-signed-2970733556
crypto pki certificate chain TP-self-signed-XXXXXXXXXXX
XXX
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name SC
ip name-server XX.XX.XXX.XX
no ipv6 cef
license udi pid CISCO887W-GN-A-K9 sn XXXXXXXX
username XXXXXXXXX privilege 15 secret 5 $XXXXXXXXXXXXXXXXXX.llpPA0
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl sync interval 180
dsl operating-mode adsl2+
dsl lom 250
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat enable
ip virtual-reassembly
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-
HWIC 4ESW$
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat enable
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat enable
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username XXXXXXX password 7 XXXXXXXXXXXXX
ppp ipcp route default
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat source static tcp 192.168.0.10 443 interface Dialer0 443
ip nat source static udp 192.168.0.10 25 interface Dialer0 25
ip nat source static tcp 192.168.0.10 25 interface Dialer0 25
ip nat source static tcp 192.168.0.10 110 interface Dialer0 110
ip nat source static udp 192.168.0.10 110 interface Dialer0 110
ip nat source static tcp 192.168.0.10 444 interface Dialer0 444
ip nat source static udp 192.168.0.10 443 interface Dialer0 443
ip nat source static tcp 192.168.0.10 3268 interface Dialer0 3268
ip nat source static udp 192.168.0.10 4125 interface Dialer0 4125
ip nat source static tcp 192.168.0.10 4125 interface Dialer0 4125
ip nat source static udp 192.168.0.10 3389 interface Dialer0 3389
ip nat source static tcp 192.168.0.10 80 interface Dialer0 80
ip nat source static udp 192.168.0.10 80 interface Dialer0 80
ip nat source list 1 interface Dialer0 overload
ip nat source static tcp 192.168.0.60 8888 interface Dialer0 8888
ip nat source static udp 192.168.0.60 8888 interface Dialer0 8888
ip nat source static udp 192.168.0.60 8090 interface Dialer0 8090
ip nat source static tcp 192.168.0.60 8090 interface Dialer0 8090
ip nat source static tcp 192.168.0.180 8080 interface Dialer0 8080
ip nat source static udp 192.168.0.180 8080 interface Dialer0 8080
ip nat source static tcp 192.168.0.180 554 interface Dialer0 554
ip nat source static udp 192.168.0.180 554 interface Dialer0 554
ip nat source static tcp 192.168.0.180 555 interface Dialer0 555
ip nat source static udp 192.168.0.180 555 interface Dialer0 555
ip nat source static tcp 192.168.0.180 556 interface Dialer0 556
ip nat source static udp 192.168.0.180 556 interface Dialer0 556
ip nat source static tcp 192.168.0.180 557 interface Dialer0 557
ip nat source static udp 192.168.0.180 557 interface Dialer0 557
ip nat source static tcp 192.168.0.180 558 interface Dialer0 558
ip nat source static udp 192.168.0.180 558 interface Dialer0 558
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
0 Replies 0
