possible to check number of current sessions ASR is handling?
donnie
Hi all,
Can i know if there is a command that i can run on my ASR1004 to check how many sessions from external is accessing or trying to access my network?
TIA!
Karan Puri
Ip cache flow wont require netflow.. configure it egress or ingress n see the result
Sent from Cisco Technical Support Android App
Karan Puri
You meant say you want to see the traffic in and out of the interface.. then go for ip cache flow , ip accounting wont help in ASRs...
Hi Karan,
Thk you for prompt response. I know i can configure netflow and use GUI to see the source and destination.
But what i like to know is if there is a command there allow me to see the number of sessions in and out of my router? Thk you!
Karan Puri
