You may be able to use a VACL to do this, but you'll need to be careful when using them to not block something that's needed. You'd do something like:
Processors Addresses:
192.168.238.50
192.168.238.51
ip access-list ext BlockMulticast
permit ip 224.0.0.0 0.255.255.255 host 192.168.238.50
permit ip 224.0.0.0 0.255.255.255 host 192.168.238.51
vlan access-map BlockMulticast 10
match ip address BlockMulticast
action drop
vlan access-map BlockMulticast 20
action forward
vlan filter BlockMulticast vlan-list 238
**** Disclaimer ****
I'm not sure if the above will block multicast traffic. Another way of doing it may be to put your processors into private vlans. If anything, I would definitely create an outage window to put this in place and see what the results are.
John
	HTH,
John
*** Please rate all useful posts ***
