Problem Connecting to Internet from LAN Behind 2811 Router and DSL Connection
tyberiuscook
First of all, I'm kinda new to the router game and I'm learning as I go.  I have a Cisco 2811 Router with a NM-16ESW card installed.  I've connected this to my DSL connecting and I'm trying to build myself a learning lab.  From the router I can ping to the internet and back to a test computer I have connected to one of the card's ethernet ports.  From the test computer, I can ping the router's WAN interface, but no further.  Here's my config...if anyone can help, I'd appreciate it and hope to return the favor one day!
Current configuration : 1931 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.15
ip dhcp pool LABTEST
   import all
   network 192.168.0.0 255.255.255.0
   default-router 192.168.2.1
no ip ips deny-action ips-interface
ip domain name LABTEST
ip name-server 8.8.8.8
interface FastEthernet0/0
ip address dhcp
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
ip nat inside
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
interface FastEthernet1/0
interface FastEthernet1/1
!interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
switchport access vlan 192
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
no ip address
interface Vlan19
ip address 192.168.2.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet0/0 overload
access-list 10 permit 192.168.0.0 0.0.0.255
access-list 101 permit icmp 192.168.0.0 0.0.0.255 any echo-reply
access-list 101 permit ip any any
no cdp run
control-plane
line con 0
password xxxxxxxxx
login
line aux 0
line vty 0 4
password xxxxxxxx
login
your interface vlan 192 must have ip nat inside configured as it is this interface which will be used by your host to route packets to distant subnets.
So do this and let us know:
int vlan 192
ip nat inside
Regards.
Alain
10 Replies 10
Reza Sharifi
Does the PC have the correct default gateway (192.168.2.1)?
Is the PC connected to interface FastEthernet1/6?
if yes, this port is added to vlan 192 while the interface vlan is configured for vlan 19
interface Vlan19
Can you change
to
and
test again?
Thanks for the reply!  The trailing 2 must've been cut off when I posted the config.  I checked again and it's definitely VLAN192 in both places.  The computer's gateway is set to 192.168.2.1.  Thanks again!
Ok, thanks for clarifying
Can you change this
to
access-list 10 permit 192.168.2.0 0.0.0.255
and test again?
Changed it.  Same problem.  The lab computer still can't get past the Fa0/0 interface.
couple more changes:
Delete
also:
delete the second line
and try again
deleted
Router will not ping to the internet now.
I replaced the line above and removed the access-list 101 line.  Still the same issue.  192.168.1.254 is the dsl modem address, BTW...if that makes a difference.
Change the DHCP IP range to be in the same network as the default gateway:
import all
network 192.168.2.0 255.255.255.0
Tried changing the DHCP pool to no avail.  It's weird...I can get back to F0/0, but I can't get any further.
int vlan 192
ip nat inside
Regards.
Alain
That was it!!!  Thanks, Cadet!!!  I feel like a dummy now, but that got me going...just tried it out!  Thanks again!
