Problem with route-maps and PBR
martinkluge
I have the following problem:
I have a Cisco 7120-SMI3 and I'm doing NAT for some customers. Other customers have static IPs which are routed over 2 different interfaces. For NAT I have a route-map applied on the outgoing interface:
route-map n permit 10
match ip address route_map_nat
set interface Dialer1
route-map n permit 20
set ip next-hop 1.1.1.1 2.2.2.2
set interface FastEthernet0/0 FastEthernet 1/0
route-map n deny 30
I also have to static default routes, one with a higher metric (floating routes).
The problem is, that when the line protocol of FastEthernet0/0 goes down,
the default route gets set to the one with the higher metric, but the route-map where I set the next-hop stillt points to the next-hop of the first interface and so the packets get to /dev/null
I thought about PBR support for multiple tracking objects, but this is only supported in 12.4 which my 7120 doesn't support (http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080457bcc.html#wp1027265)
Is there any other possible solution for my problem?
Thank you,
Martin
bwalchez
Level 4
Level 4
Try using the access list so that you can filter the trafiic to appropriate interface.On 7120 by disabling ip cef the ip policy routing works.
