Problem with routing - Need help
it4sb0001
I need a little direction with what I think is a routing problem. Any help will be appreciated. My setup is as follows:
Cable Modem
27.177.21.9
WAN - Gi0/0
27.177.21.10
Cisco 2901
LAN - Gi0/1
192.168.1.250
Client
192.168.1.10
The Problem
Router can ping LAN interface
Router cannot ping WAN interface -X
Router can ping Cable Modem
Client
Client can ping LAN interface
Client can ping WAN interface
Client cannot ping Cable Modem -X
Here is my routing table:
Gateway of last resort is 27.177.21.9 to network 0.0.0.0 (this is my cable modem)
S*    0.0.0.0/0 [1/0] via 27.177.21.9
                is directly connected, GigabitEthernet0/0
      27.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        27.177.21.8/30 is directly connected, GigabitEthernet0/0
L        27.177.21.10/32 is directly connected, GigabitEthernet0/0
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, GigabitEthernet0/1
L        192.168.1.250/32 is directly connected, GigabitEthernet0/1
Here is a portion of my configuration:
interface GigabitEthernet0/0
 description Cable Internet$FW_OUTSIDE$$ETH-WAN$
 ip address 27.177.21.10 255.255.255.252
 zone-member security out-zone
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description hbc_staff$FW_INSIDE$$ETH-LAN$
 ip address 192.168.1.250 255.255.255.0
 zone-member security in-zone
 duplex auto
 speed auto
 no mop enabled
ip default-gateway 27.177.21.9
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 27.177.21.9
ip route 192.168.1.0 255.255.255.0 27.177.21.9
 Thanks in advance
7 Replies 7
it4sb0001
Hello every one,
Another day has gone by and we are still facing the same connection issues with our new router, any help getting it working will be appreciated. Please see the first post for an explanation of our problem.
Thank you in advance.
Is the main issue internet access ?
If so where is the NAT being done for the 192.168.1.x IPs ?
1) if it is being done on the cable modem then you need a route on that device for the 192.168.1.x subnet pointing to the outside interface of your router
or
2) if you don't want to add a route to the modem (or can't) then you can NAT all 192.168.1.x IPs to the outside interface IP of your router. This way the modem knows where to send the return packets.
So what is the situation with NAT currently ?
Jon
Hello Jon and thanks for your reply.
For now I just want to make sure I can send packets from the LAN client thru the router, to the modem, and the Internet.
The status of NAT at this point is zero, I have not configure it yet. I did not think, at this point, my problem was NAT because I am able to ping from the LAN client PC to the modem and NAT will eventually happen at the WAN interface of the router later on. For now all I’m trying to accomplish is pinging to the WAN, the modem, and the Internet.
Please correct me if you still think my problem is with NAT and not with routing.
thank you in advance
In your original post you said the client could not ping the modem whereas you now say it can.
Which is it ?
Jon
Hello Jon,
I continue to try different configurations to get my router to connect without success. I am now trying NAT and this is where we stand now. Any help will be much appreciated.
The problem
Router now pings everything by ip address or name
Client PC from inside the LAN cannot ping modem or Internet
Relevant parts of configuration:
ip domain name mydomain.org
ip name-server 24.247.15.53
ip name-server 66.189.0.100
 description Internet$FW_OUTSIDE$ETH-WAN$
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
 no mop enabled
ip nat pool HBC-I 27.177.21.10 27.177.21.10 prefix-length 24
ip nat inside source list 7 pool HBC-I overload
ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/1
access-list 7 permit 192.168.1.0 0.0.0.255
#show ip route
When pinging the modem from a client inside the LAN this is what I get from NAT translations and statistics:
#sho ip nat translations ver
Pro Inside global         Inside local          Outside local         Outside global
icmp 27.177.21.10:40709   192.168.1.8:40709     27.177.21.9:40709     27.177.21.9:40709
    create 00:00:05, use 00:00:00 timeout:60000, left 00:00:59, Map-Id(In): 1,
    flags:
extended, use_count: 0, entry-id: 4, lc_entries: 0
#sho ip nat statistics
Total active translations: 2 (0 static, 2 dynamic; 2 extended)
Peak translations: 2, occurred 00:00:04 ago
Outside interfaces:
  GigabitEthernet0/0
Inside interfaces:
  GigabitEthernet0/1
Hits: 104  Misses: 0
CEF Translated packets: 104, CEF Punted packets: 0
Expired translations: 7
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 7 pool HBC-I refcount 2
 pool HBC-I: netmask 255.255.255.0
    start 27.177.21.10 end 27.177.21.10
    type generic, total addresses 1, allocated 1 (100%), misses 0
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
      Instead of this" ip route 192.168.1.0 255.255.255.0 27.177.21.9"
        Change it to "ip route 192.168.1.0 255.255.255.0 gig0/0"
Chandhuru.M
Thanks and regards, Chandhuru.M
Hello Chandhuru.M and thanks for your reply.
After changing the route to what you suggested, I still have the same problem pinging across to the WAN interface and the modem. Now the LAN client PC and the router can only ping the LAN interface. Please refer back to the original post for a description of my setup. After the change you proposed, this is what I have:
Please note the Gateway of last resort is now not set.
hbc_gateway#show run | include route
ip route 0.0.0.0 0.0.0.0 24.176.21.9
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/0
hbc_gateway#sho ip route
Gateway of last resort is not set
Any other suggestions at this point?
