Problem with VPN and Access List
xSaschx
i have build up a trainings network with a C891F Router
The Router have the internal IP 192.168.51.1 and Outside 192.168.50.216
The VPN Clients get an ip address from 192.168.52.100 - 192.168.52.150
this is all working.
now i want to set up access Lists.
i set up an access List
ip access-list extended OUTSIDE-IN
permit udp any any eq isakmp non500-isakmp
permit ip 192.168.52.0 0.0.0.255 any
deny ip any any
ip access-list extended INSIDE-OUT
permit ip any any
and on the WAN interface
interface GigabitEthernet8
  ip address dhcp
  ip access-group OUTSIDE-IN in
  ip access-group INSIDE-OUT out
  duplex auto
  speed auto
  crypto map map1
and now the clients can not ping the router
Where is my Error ??
You are still missing ESP in your ACL. This is the correct ACL:
 permit esp any any
 deny   ip any any
13 Replies 13
Is the rest of the VPN working? Can they ping internal systems? At least if there is no NAT between client and router, you also need to allow IP/50 (ESP). And the "permit ip 192.168.52.x ..." is not needed nowadays (it was needed a very long time ago).
I can only Connect to the VPN but cannot ping anything . Here is the complete Config. I want to set up a easy VPN for Training . I have set now a acl in the crypto group but not working.
version 15.3
service config
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
aaa new-model
aaa authentication login VPN1 local
aaa authorization network VPN2 local
aaa session-id common
service-module wlan-ap 0 bootimage autonomous
ip dhcp excluded-address 192.168.51.1 192.168.51.10
ip dhcp excluded-address 192.168.51.100 192.168.51.254
ip dhcp pool LAN
 network 192.168.51.0 255.255.255.0
 default-router 192.168.51.1
 dns-server 192.168.51.1
ip inspect name FW tcp router-traffic
ip inspect name FW udp router-traffic
ip inspect name FW icmp router-traffic
ip inspect name FW ftp
ip cef
no ipv6 cef
license udi pid C891FW-E-K9 sn xxxxxxxxxxxxx
username user secret 5 $1$mAfgfgfgfdgfdggfk4V0bDmw.
crypto isakmp policy 10
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp client configuration group cisco
 key Key123
 pool VPNPOOL
 acl 120
crypto ipsec transform-set set1 esp-3des esp-md5-hmac
 mode tunnel
crypto dynamic-map map1 10
 set transform-set set1
crypto map map1 client authentication list VPN1
crypto map map1 isakmp authorization list VPN2
crypto map map1 client configuration address respond
crypto map map1 10 ipsec-isakmp dynamic map1
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
 ip address dhcp
 ip inspect FW out
 duplex auto
 speed auto
 crypto map map1
interface Wlan-GigabitEthernet8
 no ip address
interface wlan-ap0
 description Embedded Service module interface to manage the embedded AP
 no ip address
interface Vlan1
 ip address 192.168.51.1 255.255.255.0
interface Vlan10
 ip address 192.168.52.1 255.255.255.0
interface Async3
 no ip address
 encapsulation slip
ip local pool VPNPOOL 192.168.52.100 192.168.52.150
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.50.1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
 permit ip any any
 deny   ip any any
access-list 120 permit ip 192.168.51.0 0.0.0.255 192.168.52.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 stopbits 1
line 3
 modem InOut
 speed 115200
 flowcontrol hardware
line vty 0 4
 transport input all
scheduler allocate 20000 1000
end
xSaschx
No i cannot ping anything. and no - i don´t want NAT. i have set routes between the routers.
Here is the complete Config . Maybe you can help me to fix it
version 15.3
service config
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
aaa new-model
ip dhcp pool LAN
ip cef
no ipv6 cef
username user secret 5 $1$mfgdgrhrrfsgR2k4V0bDmw.
 encr 3des
 hash md5
 group 2
 key Key123
 pool VPNPOOL
 acl 120
 mode tunnel
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 ip address dhcp
 ip inspect FW out
 duplex auto
 speed auto
 crypto map map1
 no ip address
interface wlan-ap0
 no ip address
interface Vlan1
interface Vlan10
interface Async3
 no ip address
 encapsulation slip
no ip http server
 permit ip any any
 deny   ip any any
control-plane
line con 0
 no modem enable
line aux 0
line 2
 no exec
 transport input all
 stopbits 1
line 3
 modem InOut
 speed 115200
line vty 0 4
 transport input all
end
 permit esp any any
 deny   ip any any
Wow thank you - now it works ;o))
Is it possible to connect with a any Connect Client to this kind of VPN ??
In general yes, but not with that config. And you need to license the AnyConnect client.
Ok thank you for your Help
How i can get information about the any Connect Licence ??
AnyConnect Ordering Guide
AnyConnect Licensing Frequently Asked Questions (FAQ)
Here is a guide for configuring the router for AnyConnect. A little bit older, but should still work:
AnyConnect: Configure Basic SSLVPN for IOS Router Headend With the Use of CLI
Perfect thank you. I have orderd a FL-WEBVPN-10-K9 pack for my C891F Router. I have also a C891FW for testing. Is it possible to activate a Demo WebVPN licence on the Test Router for Testing it first ??
Not sure how you ordered that, as this license is EOS. And if you could buy it, I expect that it won't give you any download-rights on the AnyConnect software. As pointed out in the ordering guide and FAQ, you need the AnyConnect PLUS-License.
I have bought it at a dealer by EBay. I got the Licence but there is no PAK code included. Only a Letter . "This Letter serves as a feature license that entitles you to activate WebVPN in one Cisco IOS Device...."How i can activate now the licence in my Router ??
Ok it was a RTU (right to use)license. The dealer give me now a FL-SSLVPN10-K9 which it was a license with a PAK code. I hope i can activate it. It is also EOL but i need it only for Privat Training. Licensing is very complicated witch Cisco ;o))
