04-14-2023 09:54 PM
I have configure the main GigabitEthernet 0/0/0 interface to successfully connect to my ISP and from the router CLI I can ping the outside world.
On my private network side (192.168.3.0) i have configured a VLAN (192.168.3.1)and added one of my L2 interfaces GigabitEthernet 0/1/3 to the VLAN. I have also configure NAT inside.
For some reason, from my PC using 192.168.3.3 is not able to ping the outside world. I can successfully ping both internal and external interfaces on the router but cannot get further.
If anyone is able to help review my config I would be most grateful.
============== config===================
#show running-config
Building configuration...
Current configuration : 6792 bytes
! Last configuration change at 14:33:31 UTC Sat Apr 15 2023
! NVRAM config last updated at 14:30:19 UTC Sat Apr 15 2023 by admin
version 16.10
service call-home
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname router
boot-start-marker
boot-end-marker
logging console emergencies
enable secret 9 XXXX
enable password XXXX
no aaa new-model
clock timezone UTC 10 0
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
ip dhcp excluded-address 192.168.3.1 192.168.3.50
ip dhcp pool lan-pool
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
dns-server 8.8.8.8
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-xxxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-xxxx
revocation-check none
rsakeypair TP-self-signed-xxxx
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate chain TP-self-signed-1698198237
certificate self-signed 01
30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
quit
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
quit
crypto pki certificate pool
cabundle nvram:ios_core.p7b
license udi pid C1111-4P sn xxxx
diagnostic bootup level minimal
username admin privilege 15 password 0 cisco
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
ip address dhcp
ip nat outside
negotiation auto
spanning-tree portfast disable
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
switchport mode access
interface Vlan1
ip address 192.168.3.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 xxx.xxx.4.1
ip route 0.0.0.0 0.0.0.0 xxx.xxx.4.1
access-list 1 permit 192.168.3.0 0.0.0.255
route-map track-primary-if permit 1
match ip address 197
set interface GigabitEthernet0/0/0
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
password xxxx
login
length 0
end
Solved! Go to Solution.
04-15-2023 12:28 AM
ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload <<- remove this command
04-15-2023 02:04 AM
I agree that route map appears to be related more to Policy Based Routing than to NAT. Also it references an access list that does not exist. Remove the nat statement, and I would suggest removing the route map as well.
There are 2 somewhat overlapping static routes
I would suggest removing one of them.
I note that the config has both enable secret and enable password. When enable secret is used then enable password is ignored. I suggest that you remove enable password.
04-15-2023 02:45 AM
there is only outside
config ip nat inside under the VLAN1 interface
04-15-2023 12:28 AM
04-15-2023 02:04 AM
04-15-2023 02:21 AM
thanks you @Richard Burts I have made those two changes - removed the second static route. no change to behaviour though unfortunately
04-15-2023 01:59 PM
I am glad to know that you made the changes that I suggested. Perhaps I could have been a bit more clear that while my first suggestion (about the route map) was related to the problem in your post my other suggestions were about how to improve the configuration, but not related to the problem with Internet access. There is no benefit in having 2 static routes that have the same next hop, and that provides a (small) complication in the configuration (if there were to be some problem, how do you determine which static route was being used). So I suggest removing one static route. Similarly if enable secret is configured then enable password is ignored. If it serves no useful purpose in the config and presents a (small) complication in the config they I suggest that it be removed.
04-15-2023 02:19 AM
thank you @MHM Cisco World i have removed that. no change to result though
04-15-2023 02:45 AM
04-15-2023 05:32 AM
BINGO! thanks @MHM Cisco World
04-15-2023 05:49 AM
You are so so welcome
