QoS Configuration for VoIP
suredatasystems
i try to configure QoS on a Cisco Small Business SG300 Switch. I followed the instruction on https://supportforums.cisco.com/docs/DOC-13461 and configured one Port for tagging my Traffic from a Aastra IP Phone. Tagging works fine (i verified with wireshark).
The problem is, that all traffic to a PC connected directly to the Aastra IP Phone is blocked. Is there a possibility to tag any other traffic to the port as a default?
Thx for your help!
sandbankhomes
I'm having a similiar problem on the Cisco SF-300 switch. I followed the same document and configured one port for testing. All traffic to/from that port is now blocked. Have you had any luck resolving your issue?
