QOS with CEF enabled . and strict prioritization
santoshvijapur
  I have 6509 core switch . where CEF is ruunning .  I am applying  QOS for  the one of the application
where  I am calling ACL  and defining    1) perimit ip host 10.200.250.10 any
                                                          2) permit udp range 49000 49100 any
In clas-map OCS  for the ACL i am marking ip  precedence  5 .  and applying  on the interface
for the second statement of ACL  i am finding  hits  , same time for the first statement ACL  I am not finding ACL hits .
As CEF being eanbled  is that reason i am not finding hits at ACL at first statement  and not marking the packets for precedence 5 .
Is there any way to check precedence 5 has been marked for the packetes . please suggest .
Also  would like to know, If I created 2  classes at LLQ  as per below configuration  .
1) class  VOICE QUEUE marking at precedence  5  ,  strict priority configured   .
2)  class BUSINESS CLASS  marking precedence 1   , strict priority configured .
In this scanario , whch traffic will be priotized  FIRST at router , when traffic hits to the, Lan interface  buffer memory .please guide .
1) Class-map: VOICE-QUEUE (match-any)
      28029 packets, 6802733 bytes
      30 second offered rate 1000 bps, drop rate 0 bps
      Match: access-group 150
        30 second rate 1000 bps
      Priority: 30% (24000 kbps), burst bytes 600000, b/w exceed drops: 0
      QoS Set
        precedence 5
          Packets marked 28029
    2) Class-map: BUSINESS-CLASS-QUE (match-any)
      2296314 packets, 482676020 bytes
      30 second offered rate 28000 bps, drop rate 0 bps
      Match: access-group 152
        30 second rate 28000 bps
      Priority: 40% (32000 kbps), burst bytes 800000, b/w exceed drops:
       QoS Set
        precedence 1
          Packets marked 2296669
jonathanaxford
Level 3
Level 3
Hi there,
In answer to your frst question, I usually use wireshark to capture some packet as and make sure that they have been marked correctly.
With regards to your second question, this thread may have some information that will be useful to you:
https://supportforums.cisco.com/message/819614;jsessionid=1C2B422DEE3F12AE56AF02EA167B2D76.node0
Hope this helps,
Jonathan
Thanks for your valuable tips .
