Question concerning Port-Indexing on a Cisco 2960
derplord1234
My task is to find out the neighbors of the 2960 on the port with SNMP.
iso.0.8802.1.1.2.1.4.1.1.7 ->
     iso.0.8802.1.1.2.1.4.1.1.7.0.25.1 = STRING: "1/g23"
As far as I understand that does mean that on local port 25 there is a connection to 1/g23 of the connected switch.
But...
IF-MIB::ifIndex
     IF-MIB::ifIndex.10123 = INTEGER: 10123
     IF-MIB::ifIndex.10124 = INTEGER: 10124
     IF-MIB::ifIndex.10125 = INTEGER: 10125
     IF-MIB::ifIndex.10126 = INTEGER: 10126
     IF-MIB::ifIndex.10127 = INTEGER: 10127
Is the port with the index 10125 the same as just 25 above?
Rolf Fischer
Level 9
Level 9
you can validate the different interface enumeration types with
1) LLDP-MIB::lldpLocPortId
Example:
iso.0.8802.1.1.2.1.3.7.1.3.1 = "Fa0/1"
iso.0.8802.1.1.2.1.3.7.1.3.2 = "Fa0/2"
2) CISCO-STACK-MIB::portIfIndex
Example:
enterprises.9.5.1.4.1.1.11.1.1 = 10001
enterprises.9.5.1.4.1.1.11.1.2 = 10002
ifName.10001 = Fa0/1
ifName.10002 = Fa0/2
Hope that helps
Rolf
Rolf Fischer
Level 9
Level 9
Example:
Example:
Hope that helps
Rolf
Thank you, that was exactly what I needed :)
