Recommend switch/router capable of pseudowire L2TPV3 with 10G ports
virgo
I'm looking for a bare minimum device, preferably Cisco that is capable of tunnelling multiple VLANs via a single VLAN for the purpose of delivering a Layer 2 circuit via a leased fibre line. Need a minimum 2 x TE ports to tunnel traffic up to 10Gbps.
Currently using ASR920 / ASR1001, however feel that it's overkill for the sole purpose as above.
I'm not well versed on the Cisco product offering and would like some thoughts on what other models which will fulfil the same purpose.
acampbell
I suggest that you look at the Cisco Feature navigation tool.
https://cfnng.cisco.com/browse/routing/features
Looking at L2TPV3 there are many platforms to choose from.
Regards, Alex. Please rate useful posts.
