Redundant Switch Block Design Question
ksbolton1
Hello all. Quick question. I'm currently reading up on some CCNP switch topics, started from basics and I encountered the below diagram. ImI just seeking some clarification on why there's a Layer 2 link between the distribution switches. I'm assuming it's because access switch on the right has to be able to send Vlan A traffic over that link in case its link to the distribution switch on the left goes down but I'm unsure. Could someone please help me to understand this?
omz
Thats right!
The design is not optimal for a large network because the VLANs are end-to-end (exist on both dist and access switches) and not localised.
Consider 80:20 Rule for good design practice - 80% of the traffic should not cross the LAN and a good practice is to have local VLANs with Layer 3 routing between them.
Hope this helps.
Please rate helpful posts :)
Leo Laohoo
Distro switches are suppose to have high-speed links between the distro and the access switch. Distro switch is also mean to have a large MAC address table.
So access switch 1 needs to send something to a client in access switch 2. But since they 1 & 2 are not connected to each other directly, the data needs to go up to distro, the distro performs his check and finds out where the client in 2 is and sends the data downstream.
omz
Thats right!
Hope this helps.
