05-06-2014 02:46 AM - edited 03-07-2019 07:20 PM
same IOS version
WS-C2960S-24PS-L
for
WS-C2960S-48LPS-L
Whats the best way to do this without powering down the stack.
thanks
Solved! Go to Solution.
05-06-2014 03:06 AM
05-06-2014 03:54 AM
If you use your method, there will be MORE disruption to clients connected to switch 3 because you need to reboot switch 4/3 TWICE.
With my method, your disruption is minimized to just ONE disruption.
Your choice.
05-06-2014 03:06 AM
05-06-2014 03:08 AM
will the stack detect the 48 port switch and allow me to config all its ports or will it still remember only 24 ports ?
05-06-2014 03:16 AM
Let us presume that your 24-port is switch 3 in the stack. So you can remove the configuration of the 24 port by using this command:
config t
no switch 3 provision WS-C2960S-24PS
switch 3 provision WS-C2960S-48LPS
<You can start configuring your ports EVEN BEFORE you connect the 48-port switch to your stack>
end
Please don't forget to rate our useful posts.
05-06-2014 03:20 AM
the stack contains 3 switches
could i provison the new switch as number 4 and config the ports
then remove switch 3 and convert switch 4 to number 3?
05-06-2014 03:54 AM
Your choice.
05-06-2014 04:22 AM
OK
but i gain time configing the ports before (multiple vlans)
as you say ... my choice
thanks
