restricting bandwidth using class-map, policy-map and service-policy
donnie
I am trying to use class-map, policy-map and service-policy on a cisco 1841 to do a test to ensure that traffic between 192.168.5.x and 192.168.6.x network is at only 10Kbps. As i want to achieve traffic restriction for certain protocols eventually. However when i do a data transfer between the 2 networks it is still at more than 10Mbps. Below is my 1841 config. Pls advise what is wrong, thks in advance.
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging buffered 52000 debugging
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.5.101 192.168.5.254
ip dhcp pool pbxpool
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.254
   lease 0 8
ip domain name yourdomain.com
username ciscoadm privilege 15 secret 5 $1$iJEz$WHEd17LLFVRpAbyTtMpLn.
class-map match-any maptest
match access-group 101
policy-map policytest
class maptest
  bandwidth 10
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ETH-LAN$
ip address 192.168.5.254 255.255.255.0
duplex auto
speed auto
service-policy output policytest
interface FastEthernet0/1
description $ETH-LAN$
ip address 192.168.6.254 255.255.255.0
duplex auto
speed auto
ip classless
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 101 permit ip 192.168.5.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 101 permit ip 192.168.6.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 102 permit ip any any
access-list 102 permit icmp any any
control-plane
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege le
vel of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username <myuser>  privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to use
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
transport input none
end
cadet alain
to limit traffic bandwidth you must do CB-policing and so you must replace the bandwidth command in
class maptest
  bandwidth 10
by police 10000  conform-action transmit exceed-action drop
Then apply this policy inbound on fastethernet interface
Regards.
Alain
