Router Netflow Help Required
Ali Haider
Dear All,
I have one R1<-->connected to <-->R2 and R2 is connected to R3. i have enable the Netflow on R2 that is when R1 ping R3 IP it shoudl generate the netflow as follow.
  • Define an ip flow-top-talkers policy to be applied to R2 as follows:
    • Display the top 5 talker for ICMP traffic
    • Randomly sample traffic at a rate of one-out-of 10 packers
  • Verbose netflow output must display:
    • IP addresses
    • MAC Addresses
    • VLAN IDs
Follwing are the configuration i made, it is only showing the IP address but i need to get the MAC Address and VLAN as well in show ip cache verbose flow command omn R2.
R2-Configuratoin
ip cef
class-map ICMP
match protocol icmp
ip flow-export version 9
flow-sampler-map NF
mode random one-out-of 10
ip flow-top-talkers
top 5
sort-by packets
match source address 7.7.6.0/24
match destination address 7.7.4.1/32
match flow-smapler NF
interface Gi0/1
flow sample NF
I make the ping from R1 to R3
R1#ping 7.7.4.1
following is the show output, i need to get the MAC and VLAn as well how i can do it?
R6#sh ip cache verbose flow
IP packet size distribution (2228 total packets):
   1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
   .000 .003 .724 .262 .004 .003 .000 .000 .000 .000 .000 .000 .000 .000 .000
    512  544  576 1024 1536 2048 2560 3072 3584 4096 4608
   .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 4456704 bytes
  2 active, 65534 inactive, 558 added
  10614 ager polls, 0 flow alloc failures
  Active flows timeout in 30 minutes
  Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 533256 bytes
  0 active, 16384 inactive, 0 added, 0 added to flow
  0 alloc failures, 0 force free
  1 chunk, 1 chunk added
  last clearing of statistics never
Protocol         Total    Flows   Packets Bytes  Packets Active(Sec) Idle(Sec)
--------         Flows     /Sec     /Flow  /Pkt     /Sec     /Flow     /Flow
UDP-other            4      0.0         2   127      0.0       0.0      15.5
ICMP                 6      0.0         3    90      0.0       1.8      15.3
IP-other           546      0.0         3    94      0.2       3.0      15.5
Total:             556      0.0         3    94      0.2       3.0      15.5
SrcIf          SrcIPaddress    DstIf          DstIPaddress    Pr TOS Flgs  Pkts
Port Msk AS                    Port Msk AS    NextHop              B/Pk  Active
Fa1/1.1        7.7.6.5         Fa1/0          7.7.8.2         32 C0  10       3
B0BA /0  0                     0B7F /0  0     0.0.0.0                96     0.0
Sampler: 1
Fa1/1.1        7.7.6.4         Fa1/0          7.7.4.1         01 00  10       3
0000 /0  0                     0800 /0  0     0.0.0.0                94     3.3
Sampler: 1
sh ip flow top-talkers
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP  Pkts
Fa1/1.1       7.7.6.4         Fa1/0         7.7.4.1         01 0000 0800     3
1 of 5 top talkers shown. 1 of 3 flows matched.
Ali
Damien Miller
You may want to try the following two commands as vlan id and mac's are not recorded by default.
ip flow-capture mac-addresses
ip flow-capture vlan-id
The ip flow-capture mac-addresses command captures the incoming source mac-address and the outgoing destination mac-address from the first Layer 2 frame in the flow. If you discover that your network is being attacked by Layer 3 traffic, you can use these addresses to identify the device that is transmitting the traffic that is being received by the router and the next hop or final destination device to which the router is forwarding the traffic.
A VLAN is a broadcast domain within a switched network. A broadcast domain is defined by the network boundaries within which a network propagates a broadcast frame generated by a station. Some switches can be configured to support single or multiple VLANs. Whenever a switch supports multiple VLANs, broadcasts within one VLAN never appear in another VLAN.
http://www.cisco.com/en/US/docs/ios/12_3t/netflow/command/reference/nfl_a1gt_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1185290
