routing a packet through network
carl_townshend
Hi all, when a packet goes from a source to a destination, at each hop towards the destination, does the source ip address or mac address change to the previous hops router?
Harold Ritter
Carl,
Generally speaking, only the destination MAC address would change from hop to hop. The source and destination IP adddresses would remain the same from source to destination (given that NAT is not used).
Hope this helps,
mohammedmahmoud
Level 11
Level 11
When a packet is routed via a router or Layer 3 switched from a source in one subnet to a destination in another subnet, the router/L3 Switch performs a packet rewrite at the egress port:
Packet rewrite alters five fields:
Layer 2 (MAC) destination address
Layer 2 (MAC) source address
Layer 3 IP Time to Live (TTL)
Layer 3 checksum
Layer 2 (MAC) checksum (also called the frame checksum or FCS)
Note: Packets are rewritten with the encapsulation appropriate for the next-hop subnet.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
