Routing between subnets on separate routers
Matt Cornall
Hi guys,
Little stuck with a router config, can't get the networks to speak to each other - new to this but can't see why this shouldn't work!
Router1
Fa0/0 connected to a switch and advertising 10.1.1.0/24 (10.1.1.1 assigned)
Fa0/1 connected to Router2 via 10.9.9.8/31 (10.9.9.9 assigned)
Router2
Fa0/0 connected to a switch and advertising 192.168.1.0/24 (192.168.1.1 assigned)
Fa0/1 connected to Router1 via 10.9.9.8/31 (10.9.9.10 assigned)
All ports are configured and up, and I can ping from hosts to routers on both sides and between routers but the traffic won't cross routers from 192.168.1.0/24 into 10.1.1.0/24 over the 10.9.9.8/31, what am I missing?
Matt
acampbell
Hi Matt,
Have you actually added the static routing you require to route accross the network
Router 1
ip route 192.168.1.0 255.255.255.0 10.9.9.10 name route-to-router2
Router 2
ip route 10.1.1.0 255.255.255.0 10.9.9.9 name route-to-router1
Also will you change the mask on subnet 10.9.9.8/31 tp 10.9.9.8/30 (255.255.255.252)
if you want to use .9 & .10
Alex
Regards, Alex. Please rate useful posts.
Says "invalid next hop (it's the router)
Please see attached topology
I can ping;
From PC1 to 10.1.1.1 + 10.9.9.9
From PC0 tp 192.168.1.1 + 10.9.9.10
From Router0 to Router1
From Router 1 to Router0
I Cannot ping;
From PC1 to 10.9.9.10
From PC0 to 10.9.9.9
Basically whenever the connection passes between routers
Hi Matt,
Looking at your diagram
You need to get the masks sorted out on both routers
Your router configs should be:-
Router 0
host router0
int fas0/0
desc *** *** ROUTER 0 PC LAN *** ***
ip add 10.1.1.1 255.255.255.0
no shut
int fas0/1
desc *** ROUTER 0 to ROUTER 1 WAN ***
ip add 10.9.9.9 255.255.255.252
no shut
ip route 192.168.1.0 255.255.255.0 10.9.9.10 name route-to-router1
Router 1
host router1
int fas0/0
desc *** *** ROUTER 1 PC LAN *** ***
ip add 192.168.1.1 255.255.255.0
no shut
int fas0/1
desc *** ROUTER 1 to ROUTER 9 WAN ***
ip add 10.9.9.10 255.255.255.252
no shut
Make sure that the PCs have the local router address as their default gateways
Alex
Hi Alex,
Thanks for getting back to me, the subnets look correct to me?
10.9.9.8/30 =
10.9.9.8 Network
10.9.9.9-10 hosts (assigned)
10.9.9.9.11 Broadcast
Doesn't it?
/30 = 255.255.255.252
