Routing concept
I have cisco 9500 switch.
I have 2 interface for communicate with outside.
I have 5 VLANs (VLAN10, VLAN20, VLAN30, VLAN40 and VLAN50)
VLAN10 ip address : 10.10.10.1/24
VLAN20 ip address : 20.20.20.1/24
VLAN30 ip address : 30.30.30.1/24
VLAN40 ip address : 40.40.40.1/24
VLAN50 ip address : 50.50.50.1/24
2:  wan interface is x.x.x.x and gateway is a.a.a.a
      wan interface is y.y.y.y and gateway is b.b.b.b
My requrement is
VLAN10,VLAN20,VLAN30 and VLAN50 traffic will goes through wan interface x.x.x.x
and only VLAN50 traffic will goes through wan interface y.y.y.y
but same time my default route will be in routing table that is
0.0.0.0 0.0.0.0 x.x.x.x
how i will route the traffic
5 Replies 5
Reza Sharifi
see your other post.
Richard Burts
If I am understanding your post correctly you have multiple vlans/multiple subnets. You want most subnets to route to outside using one interface and other subnet to route to outside using a different outside interface. The usually way to accomplish this is to use Policy Based Routing. You will find some information about this feature in this link
https://www.cisco.com/c/en/us/td/docs/ios/12_2/qos/configuration/guide/fqos_c/qcfpbr.html
Rick
Rick
Alternatively, put VLANs 10,20,30 & 40 in one VRF and VLAN 50 in another. Each VRF has its own default route and route leak (or interconnect) between the VRFs.
Hope this helps
Dave
how i wil do can you suggest me...........can you give me configuration file
It will helpful for me
Here is a config example covering PBR and inter-VRF route leaking:
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/200158-Configure-Route-Leaking-between-Global-a.html
Hope this helps
Dave
