routing solution
zeuscyril
Level 4
Level 4
hi all,
i am attaching one network diagram , in that i need traffic flow on both side
the place which i put ??? mark wat device i can use , i can use normal home router.
or anyother possible solution for this kind of network.
lgijssel
Level 9
Level 9
If the number of ports on your existing 887 is not sufficient, you can place an 881 there:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542_ps380_Products_Data_Sheet.html
You may also use a switch to connect multiple devices to the same interface of the router.
regards,
Leo
zeuscyril
Level 4
Level 4
hi leo,
it doesnt matter the ports , what i need is to able to communicate both the subnets from otherside .
but the vpn is terminating on 10.60.1.0 not on the 192.168.1.0
i am using one ip from 10.60.1.0 network as outside interface of 192.168.1.0 network
i am able to ping from 192.168.1.0  to 193.169.1.0 but revrese is not happening.
thanks
cyril
On internet or the tunnel?  have you enabled icmp inspection on the ASA?
Regards.
Alain.
Is 192.168.1.0 a new addition to the network? if so have you adjusted the ACL that the IPSec uses to identify traffic to be sent over the VPN?
Please remember to select a correct answer and rate helpful posts
