Routing vlans without a trunk
erdiazgue
Is there a way to route between 2 vlans WITHOUT using vlan trunking and using only 1 cable between the Router and the Switch.
Scenario:
Router
Switch
Vlan1 Vlan2
8 Replies 8
Richard Burts
Ernesto
Given the limitations of 2 VLANs on the switch, one cable from the switch to one interface on the router, I do not believe that Inter-VLAN routing is possible without trunking (UNLESS the switch happens to be a layer 3 switch which can do its own Inter-VLAN routing).
Rick
Rick
Hi Rick,
It's a switch layer 2.
Francois Tallet
Level 7
Level 7
Not with a Cisco switch afaik. You need a trunk or two physical links between the router and the switch.
Francois
BTW, why is that requirement? Are you trying to do something similar to private vlans? (private vlans might help here)
Francois
Hi Francois,
It was a challenge Lab. I didn't get to know what was the correct answer thats why I wanted to doublecheck with the forum if there could be any possible way around given the limitations.
Do you think it could be possible using private vlans?
Oh I see;-)
Yes, I guess they were expecting private vlans here. A promiscuous port allow you to have l3 connectivity between two private vlans while preventing direct l2 connectivity. Now, of course, you can challenge the fact that the two vlans are different, as they share the same primary vlan;-)
Francois
markwgallagher
I'm pretty sure you can use Subinterfaces on each side if you run ios on both sides...
you'll still have some 802.1q config, but it would look something this:
ROUTER
interface GigabitEthernet2/0
description ROUTER
ip address 10.14.2.254 255.255.255.0
interface GigabitEthernet2/0.1
encapsulation dot1Q 1 native
no snmp trap link-status
no cdp enable
no shut
interface GigabitEthernet2/0.14
description ROUTER-OPER-NET-GATEWAY
encapsulation dot1Q 14
ip address 10.14.1.254 255.255.255.0
ip access-group lan-ROUTER-OPER-in in
ip access-group lan-ROUTER-OPER-out out
interface GigabitEthernet2/0.114
description ROUTER-MGMT-NET-GATEWAY
encapsulation dot1Q 114
ip address 10.19.14.254 255.255.255.0
ip access-group lan-ROUTER-MGMT-in in
ip access-group lan-ROUTER-MGMT-out out
no shut
SWITCH
interface GigabitEthernet0/1
description SWITCH
ip address 10.14.2.253 255.255.255.0
interface GigabitEthernet0/1.1
no cdp enable
no shut
interface GigabitEthernet0/1.14
description SWITCH-OPER-NET-GATEWAY
ip address 10.14.1.253 255.255.255.0
ip access-group lan-SWITCH-OPER-in in
ip access-group lan-SWITCH-OPER-out out
interface GigabitEthernet0/1.114
description SWITCH-MGMT-NET-GATEWAY
ip address 10.19.14.253 255.255.255.0
ip access-group lan-SWITCH-MGMT-in in
ip access-group lan-SWITCH-MGMT-out out
no shut
Thanks for the answer, I'm sure this could work, but the challenge question was without using trunking (without using ISL or dot1q)
BTW In the scenario both the switch and router are Cisco, and the switch is a layer 2 device.
