Routing
jonk34567
Level 4
Level 4
How does a router handle an incoming packet whose destination network is missing from the Routing table?
A. it discards the packet.
B. it broadcasts the packet to each network on the router.
C. it routes the packet to the default route.
D. it broadcasts the packet to each interface on the router.
Jon Marshall
What do you think it does and why ? (
If you simply just keep asking questions how will you develop the skills to work these things out.
Jon
my opinion is "C" but answer is A . i need an explanation
If there was a default route then you would be right but the question does not say there is a default route in the routing table.
As with many of these questions they seem designed to catch you out as much as test your knowledge.
Jon
