RSTP CCIE Lab
alfredobosca
I have deployed the network topology showed below and I was surprised after found out that there isn't Backup ports. I am concern because the RSP role of ports are: Root Port, Designated Port, Alternative Port, Backup Port. After read all INE documentations I understood that AP is the alternative path to reach the Root Bridge;therefore only should be one unique AP each switch. I For example on CCIE2 Switch the RP is Fa0/23 and the Fa0/24 would be the unique Alternative Port.
I attach the outputs:
CCIE1
VLAN0020
  Spanning tree enabled protocol rstp
  Root ID    Priority    32788
             Address     001c.b02f.8f00
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32788  (priority 32768 sys-id-ext 20)
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi1/0/19            Desg FWD 19        128.19   P2p
Gi1/0/20            Desg FWD 19        128.20   P2p
Gi1/0/21            Desg FWD 4         128.21   P2p
Gi1/0/22            Desg FWD 4         128.22   P2p
Gi1/0/23            Desg FWD 19        128.23   P2p
Gi1/0/24            Desg FWD 19        128.24   P2p
CCIE2#show spanning-tree vlan 20
VLAN0020
             Cost        19
             Port        25 (FastEthernet0/23)
             Address     0024.5124.3880
             Aging Time  300 sec
Fa0/19              Altn BLK 19        128.21   P2p
Fa0/20              Altn BLK 19        128.22   P2p
Fa0/21              Altn BLK 19        128.23   P2p
Fa0/22              Altn BLK 19        128.24   P2p
Fa0/23              Root FWD 19        128.25   P2p
Fa0/24              Altn BLK 19        128.26   P2p
CCIE3#show spanning-tree vlan 20
VLAN0020
             Cost        19
             Port        21 (FastEthernet0/19)
             Address     0024.14e1.4d80
             Aging Time  300 sec
Fa0/19              Root FWD 19        128.21   P2p
Fa0/21              Desg FWD 19        128.23   P2p
Fa0/22              Desg FWD 19        128.24   P2p
Fa0/23              Altn BLK 19        128.25   P2p
CCIE4#show spanning-tree vlan 20
VLAN0020
             Cost        4
             Port        21 (GigabitEthernet1/0/21)
             Address     c84c.75d0.9780
             Aging Time  300 sec
Gi1/0/21            Root FWD 4         128.21   P2p
Gi1/0/22            Altn BLK 4         128.22   P2p
mlund
Level 7
Level 7
The difference between alternative and backup is
An alternate port receives more useful BPDUs from another bridge
An backup port receives more useful BPDUs from same bridge
In Your example switch2 has 5 AP towards the root, and that is correct because all five paths is a possible path to reach root
/Mikael
