Sending Multicast Streaming by two GRE tunnels
lidium.net
Hello everyone:
I have a problem to mount two tunnels with multicast support, I have a server in the IP multicast video 192.168.1.123, group 224.1.1.1 and I must convey this to two multicast tunnels where there are several receivers. But do not get it, someone can help me with this?
Thank you for any help they can give me
pd: A diagram attached
version 12.4
hostname cisco2811
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip multicast-routing
voice-card 0
no dspfarm
username admin privilege 15 secret 5 $1$sFpN$SXXXXXXYo.KsE40
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel0
ip address 10.10.1.1 255.255.255.0
ip pim sparse-dense-mode
tunnel source Loopback0
tunnel destination 217.127.XXX.188
interface Tunnel1
ip address 10.10.2.1 255.255.255.0
tunnel destination 80.32.XXX.125
interface FastEthernet0/0
description INTERNAL_LAN$ETH-LAN$
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description WAN$ETH-WAN$
ip address 195.77.XXX.70 255.255.255.248
ip nat outside
duplex auto
speed auto
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 195.77.XXX.65
ip route 192.168.3.0 255.255.255.0 Tunnel0
ip route 192.168.4.0 255.255.255.0 Tunnel1
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip pim bidir-enable
ip nat inside source route-map salida-fibra interface FastEthernet0/1 overload
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 120 deny ip 192.168.1.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 120 deny ip 192.168.1.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 120 permit ip 192.168.1.0 0.0.0.255 any
route-map salida-fibra permit 10
match ip address 120
lidium.net
cisco2811#show ip mroute 224.1.1.1
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.1.1.1), 00:39:37/stopped, RP 0.0.0.0, flags: DC
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
FastEthernet0/0, Forward/Sparse-Dense, 00:39:37/00:00:00
(192.168.1.123, 224.1.1.1), 00:00:34/00:02:25, flags: PT
Incoming interface: FastEthernet0/0, RPF nbr 0.0.0.0
Outgoing interface list: Null
cisco2811#
