set cisco router for dhcp
zaqtivi
hi ! i want to set up r1 and r2 (see below) to get ip address from r3. what do i need to configure on all routers. thanks.
r1---r2--r3
mohammedmahmoud
Level 11
Level 11
To configure a Cisco router as a DHCP server:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca75c.html
To acquire an IP address via DHCP on an Ethernet interface of the router, use the following command in interface configuration mode:
Router(config-if)# ip address dhcp
The question is how are your routers connected (what type of interfaces), and what is the purpose of this topology.
HTH,
Mohammed Mahmoud.
With the configuration Mohammed gave you R2 would be able to get an address from R3 but not R1. Routers, by default, do not broadcasts. Any bootp request from R1 would be dropped by R2. Therefore, on R2 you need to configure the command 'ip helper-address under the interface that connects to R1. This would tell R2 to forward the bootp request to R3.
Sundar
Yes, Link provided by Mahameed is to configure the CISCO Router as DHCP Server.
Configure "ip helper-address DHCP Broadcasting Interface IP of R3.
Configure the above under the Interface connecting to R1.
Pls Rate if Helps
Best Regards,
Guru Prasad R
