setting up remote access vpn on cisco asa or router
carl_townshend
Hi all, is it possible to use my windows local vpn client to connect to a cisco asa or router , or do i need cisco vpn client ?
irisrios
Level 6
Level 6
Yes it is possible to use local vpn client to connect to a cisco asa but the VPN Client is not able to connect to Cisco ASA 7.2(1) if the root certificate authority (CA) has two subordinate CAs.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/ezvpn505.html
http://www.cisco.com/en/US/docs/security/asa/asa71/getting_started/asa5500/quick/guide/rem_acc.html#wp1028144
