SF300-48PP Vlan questions....
Boosted240
I have a bunch of questions but I'll start with this one. I have a Fortiwifi 90d with 8 vlans. 10, 20, 30, 40, 50, 60, 70 and 80. I also have 2 cisco SF300-48PP switches set in layer 2 mode. Im trying to configure my workstation vlan (80) and voice vlan (50) on the same port due to the fact the computer is plugged into the phone and the phone to the switch.
I was able to make it work once changing to port to switchport general but from what i've read thats not ideal. I cant find switchport voice vlan as stated in older threads so Im guessing that is older cli config. I am running 1.4 firmware.
Be nice I'm a newb.
Mark Malone
Hey by default from what i remember sg300 portrs are all trunk so it should work automatically , there is no voice vlan command like in 2960s,37s etc
there is a couple of ways to do it , trunk i would have though should work as its allowing both vlans , another thing to check is that in Discovery-CDP-Interface settings you see voice vlan enabled per port
also check you can enable smartport under Port Management-Smartport-properties and interface settings you have auto smartport Device Detection set for phone + pc , for smartport to work the cdp needs to be on
Mark Malone
Thanks for your help!
