05-29-2019 06:42 AM - edited 05-29-2019 06:45 AM
I am try to configure the 2nd. SFP on ten1/1/3 but not blinking. Already changed the cable, and testet the SFP on another switch, working as fine.
I see that SFP on switch 2, has 121 on Current mA but on S1 has 38.4?
Sw1:
NAME: "Te1/1/3", DESCR: "SFP-10GBase-LR" PID: SFP-10G-LR , VID: V02 , SN: FBXPL02390 (Not Working)
NAME: "Te1/1/4", DESCR: "SFP-10GBase-LR" PID: SFP-10G-LR , VID: V02 , SN: FBXPL8618 (Working)
| Port | Temperature (Celsius) | Voltage (Volts) | Current (mA) | Optical Tx Power (dBm) | Optical Rx Power (dBm) |
| Te1/1/3 Te1/1/4 | 30.7 30.7 | 3.27 3.27 | 38.4 32.1 | -2.4 -2.7 | -0.0 -3.3 |
S1: show int ten1/1/3
TenGigabitEthernet1/1/3 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is 28ac.9e65.ad33 (bia 28ac.9e65.ad33)
Description: Til 543.072-OR1
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-LR
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 8 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
S2:
NAME: "Te1/1/3", DESCR: "SFP-10GBase-LR" PID: SFP-10G-LR , VID: V02 , SN: FBXPL02389 (Not Working)
NAME: "Te1/1/4", DESCR: "SFP-10GBase-LR" PID: SFP-10G-LR , VID: V02 , SN: FBXPL8621 (Working)
| Te1/1/3 Te1/1/4 | 31.8 27.3 | 3.27 3.29 | 120.6 34.6 | -22.8 -3.0 | -21.2 -3.7 |
S2: show int ten1/1/3
Hardware is Ten Gigabit Ethernet, address is 00fc.ba36.c1b3 (bia 00fc.ba36.c1b3)
Description: Fra 543.K11-OR02
Keepalive not set
Last input never, output 1d02h, output hang never
308 packets input, 49958 bytes, 0 no buffer
Received 308 broadcasts (230 multicasts)
0 watchdog, 230 multicast, 0 pause input
84 packets output, 12962 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
05-29-2019 07:06 AM
